天峰子
关于megui压制部分片源时,AAC音频错误的问题
(依次从下往上)如图所示,载入AVS脚本、列队、开始后,音频提示错误。我换了其他片子,没有出现问题。
单独提取片源的音频后,又可以压制了= = 不清楚是啥问题,希望有兄弟帮忙看看
错误日志:
[Error] Log
-[Information] Versions
--[Information] [2011-11-29 12:55:29] MeGUI Version : 2028 (svn)
--[Information] [2011-11-29 12:55:29] OS : Windows Server 2003 Enterprise Edition x86 SP2 (5.2.131072.3790)
--[Information] [2011-11-29 12:55:29] Latest .Net Framework installed : unknown
--[Information] [2011-11-29 12:55:29] Avisynth Version : 2.5.8.5 (2008-12-21 21:46:54)
-[Information] Update detection
--[Information] [2011-11-29 12:55:29] Connecting to server: http://megui.org/auto/stable/
--[Information] [2011-11-29 12:55:30] There are 8 files which can be updated.
-[Error] Log for job1 (audio, 腹黑妹妹控兄记(hd版)02.avs -> 腹黑妹妹控兄记(hd版)02.m4a)
--[Information] [2011-11-29 12:55:33] Started handling job
--[Information] [2011-11-29 12:55:33] Preprocessing
--[Information] [2011-11-29 12:55:33] Trying to open the file with NicAudio
--[Information] [2011-11-29 12:55:33] Failed opening the file with NicAudio(). Resize: Source image too small for this resize method. Width=0, Support=3
(H:\腹黑妹妹控兄记(hd版)\腹黑妹妹控兄记(hd版)02.avs, line 4)
--[Information] [2011-11-29 12:55:33] Trying to open the file with FFAudioSource()
--[Information] [2011-11-29 12:55:34] Failed opening the file with FFAudioSource(). FFAudioSource: Can't open 'H:\腹黑妹妹控兄记(hd版)\腹黑妹妹控兄记(hd版)02.avs'
--[Information] [2011-11-29 12:55:34] Trying to open the file with DirectShowSource()
--[Information] [2011-11-29 12:55:34] Failed opening the file with DirectShowSource()
--[Error] [2011-11-29 12:55:34] Error starting job
---[Error] [2011-11-29 12:55:34] Exception message: Calling setup of processor failed with error 'Input file cannot be opened: H:\腹黑妹妹控兄记(hd版)\腹黑妹妹控兄记(hd版)02.avs'
---[Error] [2011-11-29 12:55:34] Stacktrace: at MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job)
---[Error] [2011-11-29 12:55:34] Inner exception: null
TSField
Re: 关于megui压制部分片源时,AAC音频错误的问题
应该是输入的avs脚本的问题,贴出来看看。
压音频的时候,输入直接选择视频文件
回到 “音频编码器 / Audio encoder”
