USAGE: Spp2Pgs -i "input.ass" -s 1080 -r 23 "output.pgs"
-i <filename>
Input subtitle file name. Use '-' for a stdin raw input.
-s <format>
Frame format:
480i = 1/240/-480
576i = 2/288/-576
480p = 3/480
1080i = 4/540/-1080
720p = 5/720
1080p = 6/1080
576p = 7/576
-r <rate>
Frame rate:
23.976 = 1/23
24.0 = 2/24
25.0 = 3/25
29.97 = 4/29
30.0 = 5/30
50.0 = 6/50
59.94 = 7/59
60.0 = 8/60
-b <frameid>
Beginning index of valid frames.
-e <count>
-n <count>
count of frames.
-z[0|1]
Setting up an extra epoch at the very beginning or not.
0 = No;
1 = Yes;
(blank)= Yes. (default)
-x[0|1]
Using extremely strict mode or not.
0 = No;
1 = Yes;
-v[level]
Output level.
(blank)= All, verbose;
63 = Errors only.
127 = Errors and warnings.
144 = Normal outputs. (default)
<filename>
Output file name. Use '-' for a stdout output.
