feisty2
EDIResample
more details at https://nmm-hd.org/newbbs/viewtopic.php?f=7&t=1117
import math
import Dither
def EDIResample (src, w=None, h=None, sx=0, sy=0, sw=None, sh=None, kernel_u="spline64", kernel_d="spline36", taps=4, a1=None, a2=None, a3=None, css=None, fulls=False, fulld=None, cplace="mpeg2", nsize=0, nns=4, qual=2, etype=0, pscrn=1, noring=False, ratiothr=1.125, thr=1.0, elast=1.5, curve="linear", gcor=1.0, sigmoid=True, sigmoidthr=0.5, cont=6.5):
    core   = vs.get_core ()
    scss   = GetCSS (src)
    css    = scss if css is None else css
    fulld  = fulls if fulld is None else fulld
    Gray   = scss == "GRAY" or css == "GRAY"
    scss   = "444" if Gray else scss
    ocss   = "444" if Gray else css
    InterK = Dither.Resize16nr if noring else core.fmtc.resample
    Y      = 3
    U      = 1 if Gray else 3
    V      = 1 if Gray else 3
    Ut     = U == 3
    Vt     = V == 3
    cw     = src.width
    ch     = src.height
    cwc    = cw if scss == "444" else cw // 2
    chc    = ch // 2 if scss == "420" else ch
    ow     = cw if w is None else w
    oh     = ch if h is None else h
    owc    = ow if ocss == "444" else ow // 2
    ohc    = oh // 2 if ocss == "420" else oh
    sw     = cw if sw is None else sw
    sh     = ch if sh is None else sh
    prel   = int (sx / 2) * 2
    pret   = int (sy / 2) * 2
    prer   = int ((-cw + sx + sw if sw > 0 else sw) / 2) * 2
    preb   = int ((-ch + sy + sh if sh > 0 else sh) / 2) * 2
    prew   = cw - prel + prer
    preh   = ch - pret + preb
    if scss == "444":
       cwmod2 = int (cw / 2) * 2 == cw
       pwmod2 = int (prew / 2) * 2 == prew
       wpre   = prew < cw
       prel   = prel if wpre else 0
       prer   = (prer if pwmod2 else prer + 1) if wpre else (0 if cwmod2 else 1)
       wpre   = prew < cw or cwmod2 == False
    else:
       cwmod4 = int (cw / 4) * 4 == cw
       pwmod4 = int (prew / 4) * 4 == prew
       wpre   = prew < cw
       prer   = (prer if pwmod4 else prer + 2) if wpre else (0 if cwmod4 else 2)
       wpre   = prew < cw or cwmod4 == False
    if scss == "420":
       chmod4 = int (ch / 4) * 4 == ch
       phmod4 = int (preh / 4) * 4 == preh
       hpre   = preh < ch
       pret   = pret if hpre else 0
       preb   = (preb if phmod4 else preb + 2) if hpre else (0 if chmod4 else 2)
       hpre   = preh < ch or chmod4 == False
    else:
       chmod2 = int (ch / 2) * 2 == ch
       phmod2 = int (preh / 2) * 2 == preh
       hpre   = preh < ch
       preb   = (preb if phmod2 else preb + 1) if hpre else (0 if chmod2 else 1)
       hpre   = preh < ch or chmod2 == False
    sw     = cw - sx + sw if sw <= 0 else sw
    sh     = ch - sy + sh if sh <= 0 else sh
    sx     = sx - prel if wpre else sx
    sy     = sy - pret if hpre else sy
    sxc    = sx if scss == "444" else float (sx / 2)
    syc    = float (sy / 2) if scss == "420" else sy
    swc    = sw if scss == "444" else float (sw / 2)
    shc    = float (sh / 2) if scss == "420" else sh
    yhratio = float (ow / sw)
    yvratio = float (oh / sh)
    chratio = float (owc / swc)
    cvratio = float (ohc / shc)
    enable   = yhratio != 1 or yvratio != 1 or chratio != 1 or cvratio != 1 or sw != int (sw) or sh != int (sh) or swc != int (swc) or shc != int (shc) or sx != int (sx) or sy != int (sy) or sxc != int (sxc) or syc != int (syc)
    yhct     = math.ceil ((math.log (yhratio / ratiothr)) / math.log (2)) if yhratio > ratiothr else 0
    yhrf     = int (math.pow (2, yhct))
    yrhratio = yhratio / yhrf
    yvct     = math.ceil ((math.log (yvratio / ratiothr)) / math.log (2)) if yvratio > ratiothr else 0
    yvrf     = int (math.pow (2, yvct))
    yrvratio = yvratio / yvrf
    chct     = math.ceil ((math.log (chratio / ratiothr)) / math.log (2)) if chratio > ratiothr else 0
    chrf     = int (math.pow (2, chct))
    crhratio = chratio / chrf
    cvct     = math.ceil ((math.log (cvratio / ratiothr)) / math.log (2)) if cvratio > ratiothr else 0
    cvrf     = int (math.pow (2, cvct))
    crvratio = cvratio / cvrf
    noediy = yhct <= 0 and yvct <= 0
    noedic = chct <= 0 and cvct <= 0
    noedi  = noediy or noedic
    Yedit  = noediy == False
    Uedit  = Ut and noedic == False
    Vedit  = Vt and noedic == False
    edit   = Yedit or Uedit or Vedit
    mixed  = False if edit == False or enable == False else True
    yhchift = 0.5 if yhrf >= 2 else 0
    yvchift = 0.5 if yvrf >= 2 else 0
    yhfix   = -yhchift
    yvfix   = -yvchift
    chshift = ((0.5 if chrf >= 2 else 0) if scss == "444" else ((0.5 if chrf >= 2 else 0) if cplace == "mpeg1" else (0.5 - float (chrf / 4) if chrf >= 2 else -0.25))) if ocss == "444" else (((0.5 if chrf >= 2 else 0) if cplace == "mpeg1" else (0.75 if chrf >= 2 else 0.25)) if scss == "444" else ((0.5 if chrf >= 2 else 0) if cplace == "mpeg1" else (0.75 - float (chrf / 4) if chrf >= 2 else 0)))
    cvshift = 0.5 if cvrf >= 2 else 0
    chfix   = -chshift
    cvfix   = -cvshift
    cphfixe = 0 if ocss == "444" else (0 if cplace == "mpeg1" else 0.25 - float (0.25 / crhratio))
    cphfix  = (0 if scss == "444" else (0 if cplace == "mpeg1" else 0.25)) if ocss=="444" else ((0 if cplace == "mpeg1" else -0.5) if scss == "444" else (0 if cplace == "mpeg1" else 0.25 - float (0.25 / chratio)))
    Luma    = core.std.ShufflePlanes (src, planes=0, colorfamily=vs.GRAY) if GetCSS (src) != "GRAY" else src
    LumaL   = Dither.gamma_to_linear (Luma, fulls=fulls, fulld=fulls, curve=curve, gcor=gcor, sigmoid=sigmoid, thr=sigmoidthr, cont=cont) if curve != "linear" else Luma
    ChromaU = core.std.ShufflePlanes (src, planes=1, colorfamily=vs.GRAY) if Gray == False else 0
    ChromaV = core.std.ShufflePlanes (src, planes=2, colorfamily=vs.GRAY) if Gray == False else 0
    Linear  = core.std.ShufflePlanes ([LumaL, ChromaU, ChromaV], planes=[0, 0, 0], colorfamily=vs.YUV) if Gray == False else LumaL
    input   = core.fmtc.resample (Linear, (prew if wpre else cw), (preh if hpre else ch), (prel if wpre else 0), (pret if hpre else 0), (prew if wpre else cw), (preh if hpre else ch), kernel="point", fulls=fulls, fulld=fulls) if wpre or hpre else Linear
    if enable == False and edit == False:
       0
    elif yhct == chct and yvct == cvct and scss == "420":
       edgeedi  = EDInter (input, yvct, yhct, 1, 1, True, True, True, nsize, nns, qual, etype, pscrn)
       edgeediU = core.std.ShufflePlanes (edgeedi, planes=1, colorfamily=vs.GRAY)
       edgeediV = core.std.ShufflePlanes (edgeedi, planes=2, colorfamily=vs.GRAY)
       edgeediY = core.std.ShufflePlanes (edgeedi, planes=0, colorfamily=vs.GRAY)
    else:
       edgeediY = core.std.ShufflePlanes (input, planes=0, colorfamily=vs.GRAY) if GetCSS (src) != "GRAY" else input
       edgeediY = edgeediY if Yedit == False else EDInter (edgeediY, yvct, yhct, 1, 1, True, False, False, nsize, nns, qual, etype, pscrn)
       edgeediU = core.std.ShufflePlanes (input, planes=1, colorfamily=vs.GRAY) if Gray == False else 0
       edgeediU = 0 if Uedit == False else EDInter (edgeediU, cvct, chct, 1, 1, Ut, False, False, nsize, nns, qual, etype, pscrn)
       edgeediV = core.std.ShufflePlanes (input, planes=2, colorfamily=vs.GRAY) if Gray == False else 0
       edgeediV = 0 if Vedit == False else EDInter (edgeediV, cvct, chct, 1, 1, Vt, False, False, nsize, nns, qual, etype, pscrn)
    yrh = yrhratio > ratiothr
    yrv = yrvratio > ratiothr
    crh = crhratio > ratiothr
    crv = crvratio > ratiothr
       0
    else:
       edgeY   = edgeediY if Yedit == False else core.fmtc.resample (edgeediY, ow, oh, (sx * yhrf + yhfix), (sy * yvrf + yvfix), (sw * yhrf), (sh * yvrf), kernelh=(kernel_u if yrh else kernel_d), kernelv=(kernel_u if yrv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls)
       edgeU   = 0 if Uedit == False else core.fmtc.resample (edgeediU, owc, ohc, (sxc * chrf + chfix + cphfixe), (syc * cvrf + cvfix), (swc * chrf), (shc * cvrf), kernelh=(kernel_u if crh else kernel_d), kernelv=(kernel_u if crv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls)
       edgeV   = 0 if Vedit == False else core.fmtc.resample (edgeediV, owc, ohc, (sxc * chrf + chfix + cphfixe), (syc * cvrf + cvfix), (swc * chrf), (shc * cvrf), kernelh=(kernel_u if crh else kernel_d), kernelv=(kernel_u if crv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls)
       edge    = edgeY if Gray else core.std.ShufflePlanes ([edgeY, edgeU, edgeV], planes=[0, 0, 0], colorfamily=vs.YUV)
    yh = yhratio > ratiothr
    yv = yvratio > ratiothr
    ch = chratio > ratiothr
    cv = cvratio > ratiothr
    if enable == False and (mixed == False or (Yedit and Uedit and Vedit)):
       0
    elif yhratio == chratio and yvratio == cvratio and (mixed == False or (Yedit and Uedit and Vedit)):
       flat = InterK (input, ow, oh, sx, sy, sw, sh, cplace=cplace, kernelh=(kernel_u if yh else kernel_d), kernelv=(kernel_u if yv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls)
    else:
       flatY = core.std.ShufflePlanes (input, planes=0, colorfamily=vs.GRAY) if GetCSS (src) != "GRAY" else input
       flatY = InterK (flatY, ow, oh, sx, sy, sw, sh, kernelh=(kernel_u if yh else kernel_d), kernelv=(kernel_u if yv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls) if mixed or Yedit == False else flatY
       flatU = core.std.ShufflePlanes (input, planes=1, colorfamily=vs.GRAY) if (mixed or Uedit == False) and Ut else 0
       flatU = InterK (flatU, owc, ohc, (sxc + cphfix), syc, swc, shc, kernelh=(kernel_u if ch else kernel_d), kernelv=(kernel_u if cv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls) if (mixed or Uedit == False) and Ut else 0
       flatV = core.std.ShufflePlanes (input, planes=2, colorfamily=vs.GRAY) if (mixed or Vedit == False) and Vt else 0
       flatV = InterK (flatV, owc, ohc, (sxc + cphfix), syc, swc, shc, kernelh=(kernel_u if ch else kernel_d), kernelv=(kernel_u if cv else kernel_d), taps=taps, a1=a1, a2=a2, a3=a3, fulls=fulls, fulld=fulls) if (mixed or Vedit == False) and Vt else 0
       flat  = flatY if Gray else core.std.ShufflePlanes ([flatY, flatU, flatV], planes=[0, 0, 0], colorfamily=vs.YUV)
    merge  = (Dither.limit_dif16 (flat, edge, thr=thr, elast=elast) if mixed else edge) if edit else flat
    mergeY = core.std.ShufflePlanes (merge, planes=0, colorfamily=vs.GRAY)
    mergeY = Dither.linear_to_gamma (mergeY, fulls=fulls, fulld=fulls, curve=curve, gcor=gcor, sigmoid=sigmoid, thr=sigmoidthr, cont=cont) if curve != "linear" else mergeY
    mergeU = core.std.ShufflePlanes (merge, planes=1, colorfamily=vs.GRAY) if Gray == False else 0
    mergeV = core.std.ShufflePlanes (merge, planes=2, colorfamily=vs.GRAY) if Gray == False else 0
    mergeF = core.std.ShufflePlanes ([mergeY, mergeU, mergeV], planes=[0, 0, 0], colorfamily=vs.YUV) if css != "GRAY" else mergeY
    Range  = core.fmtc.bitdepth (mergeF, fulls=fulls, fulld=fulld) if fulls != fulld else mergeF
    return Range
def EDInter (src, vct=1, hct=1, vfield=1, hfield=1, Y=True, U=False, V=False, nsize=0, nns=4, qual=2, etype=0, pscrn=1, honly=False):
    clip = src
    if hct >= 1:
       clip   = clip if honly else core.std.Transpose (clip).std.FlipHorizontal ()
       clip   = core.nnedi3.nnedi3 (clip, hfield, True, Y, U, V, nsize, nns, qual, etype, pscrn)
       hct    = hct - 1
       honly  = hct >= 1
       hfield = 0
       clip   = clip if honly else core.std.FlipHorizontal (clip).std.Transpose ()
    else:
       0
    if vct >= 1 and honly == False:
       clip   = core.nnedi3.nnedi3(clip, vfield, True, Y, U, V, nsize, nns, qual, etype, pscrn)
       vct    = vct - 1
       vfield = 0
    else:
       0
    clip = (clip if vct <= 0 and hct <= 0 else EDInter (clip, vct, hct, vfield, hfield, Y, U, V, nsize, nns, qual, etype, pscrn, honly)) if Y or U or V else src
    return clip
def GetCSS (src):
    if src.format.id == vs.YUV420P16:
       css = "420"
    elif src.format.id == vs.YUV422P16:
       css = "422"
    elif src.format.id == vs.YUV444P16:
       css = "444"
    elif src.format.id == vs.GRAY16:
       css = "GRAY"
    else:
       css = 0
    return css
