rainy miuco
CSmod报错
vs R35
import sys
import havsfunc as haf
import mvsfunc as mvf
import CSMOD as cs
core = vs.get_core(accept_lowercase=True)
core.max_cache_size = 4500
a="D:\1.mkv"
src = core.lsmas.LWLibavSource(a,threads=1,format="yuv420p10")
#src = haf.QTGMC(src,TFF=True)
src16 = mvf.Depth(src, depth=16)
nr16 = core.knlm.KNLMeansCL(clip=src16,d = 0, a = 2, h = 1.2,device_type="GPU")
res = cs.CSMOD(nr16)
#src16=core.resize.bicubic(src16,1920,1080,filter_param_a=0, filter_param_b=0.5)
res = mvf.Depth(res, depth=10)
res.set_output()
报错log:
Failed to evaluate the script:
Python exception: No attribute with the name generic exists. Did you mistype a plugin namespace?
File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26905)
File "D:/2.0.vpy", line 16, in <module>
File "C:\Python35\lib\site-packages\vapoursynth\CSMOD.py", line 925, in CSMOD
edgemask = core.generic.Hysteresis(prewitt, prewittm,[0])
File "src\cython\vapoursynth.pyx", line 1105, in vapoursynth.Core.__getattr__ (src\cython\vapoursynth.c:20799)
AttributeError: No attribute with the name generic exists. Did you mistype a plugin namespace?
我对报错log几乎一无所知,只看懂了这个 File "D:/2.0.vpy", line 16
Re: CSmod报错
可能你需要这个genericfilters.dll
Re: CSmod报错
viewtopic.php?f=23&t=941&start=37
Holy 写了:
Xelloss0618 写了:好像最新的VapourSynth-R33.1 不支持GenericFilters了?
使用HQDering mod的时候提示找不到generic的命名空间
先從 https://github.com/vapoursynth/vapoursynth/releases 下載 R32 的 Portable,把裡面的 genericfilters.dll 複製出來用。
rainy miuco
Re: CSmod报错
NAVras 写了:viewtopic.php?f=23&t=941&start=37
Holy 写了:
因为怀疑有bug,所以vs更新到 r36,python更新到3.6,运行后报错和1楼一样。
把 genericfilters.dll 复制到VapourSynth\core64\plugins依旧报错,log如下:
Python exception: No attribute with the name focus exists. Did you mistype a plugin namespace?
File "src\cython\vapoursynth.pyx", line 1712, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:34991)
File "C:\python36\lib\site-packages\vapoursynth\CSMOD.py", line 1122, in CSMOD
sharpdiff2 = core.focus.TemporalSoften(sharpdiff,1,255,255 if chroma else 0,32,2)
File "src\cython\vapoursynth.pyx", line 1306, in vapoursynth.Core.__getattr__ (src\cython\vapoursynth.c:28067)
AttributeError: No attribute with the name focus exists. Did you mistype a plugin namespace?
Re: CSmod报错
呐~还缺focus,找起来麻烦的话,,到mawen大大的签名里找他收集的滤镜包
上次由 NAVras 在 2017-02-13 16:19,总共编辑 1 次。
rainy miuco
Re: CSmod报错
NAVras 写了:呐~还缺focus,找起来麻烦的话,,到mawen大大的签名里找他收集的滤镜包
在mawen发布的 20161209 VS Plugins+Scripts Collection 文件夹 没有找到 focus。
按照报错log:“core.focus.TemporalSoften(sharpdiff,1,255,255 if chroma else 0,32,2)”
我找到了TemporalSoften.dll。然而plugins64文件夹已经有了TemporalSoften.dll。。。
最后,我卸载了VS R36,安装了VS R33.1,什么错误都没发生。
Re: CSmod报错
嘞...
窝在用R36,plugins是自己一个个原地址找的,csmod没有报错...
Re: CSmod报错
用miscfilters,官方新版的替代。
https://forum.doom9.org/showthread.php?t=173871
Re: CSmod报错
edited.
CSMOD用了generic(例如preset=‘detail’的TEdge...)和temporalsoften(.focus)
misc在R36倒是自带了,如果改用misc楼主得改下csmod里的相关
neil_tohno
Re: CSmod报错
vapoursynth最新版 R43 也沒法用這個啊
據說CSmod 還有一些小bug一樣的問題?
