LWLibavVideoSource("I:\BluRay & DVD & HDTV\2046 2004 KOR BluRay 1080i AVC DTS-HD MA5.1-Nio@CHDBits\BDMV\STREAM\00001.m2ts")
srestore(frate=25.000, omode="pp3")
decimate(cycle=5, quality=0)
然后我去查看了一下Average的帖子,看到了那几条使用约束,但是还是不知道我这个问题应该如何解决。
附一段10s的sample:http://pan.baidu.com/s/1eQENI9O
片子的mediainfo:
General
Complete name : I:\BluRay & DVD & HDTV\2046 2004 KOR BluRay 1080i AVC DTS-HD MA5.1-Nio@CHDBits\BDMV\STREAM\00001.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 20.4 GiB
Duration : 2h 7mn
Overall bit rate : 22.8 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 2h 7mn
Bit rate mode : Variable
Maximum bit rate : 33.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Bit depth : 8 bits
Scan type : MBAFF
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 2h 7mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #3
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : Chinese
Text #4
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : Chinese
