影片信息
General
Complete name : C:\Users\reborn\Desktop\影片等候區\[SC-OL][kore wa zombie desuka][11][MKV][X264_AAC][1280X720][041A70AB]1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 416 MiB
Duration : 24mn 59s
Overall bit rate : 2 324 Kbps
Encoded date : UTC 2011-03-28 23:10:48
Tagged date : UTC 2011-03-28 23:10:48
Video
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 24mn 59s
Bit rate mode : Variable
Bit rate : 2 002 Kbps
Maximum bit rate : 9 874 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 25.871 fps
Minimum frame rate : 23.976 fps
Maximum frame rate : 119.880 fps
Original frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.084
Stream size : 386 MiB (93%)
Writing library : x264 core 75 r1246 5b3c89c
Encoding settings : cabac=1 / ref=3 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.5:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=1 / scenecut=40 / rc_lookahead=36 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=8 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2011-03-28 23:10:25
Tagged date : UTC 2011-03-28 23:10:58
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 24mn 59s
Bit rate : 160 Kbps
Maximum bit rate : 203 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 28.6 MiB (7%)
Language : Japanese
Encoded date : UTC 2011-03-28 23:10:38
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\VSFilter.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\UnDot.dll")
DirectShowSource("C:\Users\reborn\Desktop\影片等候區\kore wa zombie desuka 11 1280X720 .mp4",fps=23.976,ConvertFPS=True)
Trim(32704,34561).assumefps(60000,1001, true)
TextSub("C:\Users\reborn\Desktop\影片等候區\[SC-OL][kore wa zombie desuka][11][MKV][X264_AAC][1280X720][041A70AB].ass")
ConvertToYV12()
UnDot()
LanczosResize(720,480)
