\万岁/
版本号从0.9变成0.11了 -v-
SetMemoryMax(2048)
MPEG2Source("E:\hunter02-ts.d2v")
w=1280
h=720
deint=last.vinverse()
TFM(mode=5, pp=7, slow=2, clip2=deint).Tdecimate(mode=1)
last.trim(750, 3595)++last.trim(5400, 21890)++last.trim(24055, 36467)++last.trim(38631, 41023)
EraseLOGO(logofile="C:\Program Files (x86)\aviutl99i8\logodata.ldp", logoname="NTV 1440x1080")
src=last
c=last.spline64resize(w, h, 2, 2, -2, -1)
clip1=c.PNLM(28, 4, 0, 8).f3kdb(24, 60, 44, 44, 0, 0, 2, precision_mode=3, mt=true).GrainFactory3mod(g1str=0.85, g2str=0.35, g3str=0, g1size=0.95, g2size=0.6, g3size=0.3, temp_avg=40, ontop_grain=0)
msk=c.TEdgeMask(link=2, preblur=false, valon=-1).mt_lut("x 4 <<").mt_deflate()
clip2=src.msharpen(10, 120, mask=false, highq=true).spline64resize(w, h, 2, 2, -2, -1)
mt_merge(clip1, clip2, msk, luma=false, u=3, v=3)
MP_Pipeline("""
### platform: win32
SetMemoryMax(384)
TFM(mode=5, pp=7, slow=2, clip2=deint).Tdecimate(1)
src=last
c=last.spline64resize(1280, 720, 2, 2, -2, -1)
### export clip: c, src
### platform: win32
SetMemoryMax(512)
### export clip: clip1
### pass clip: c, src
### platform: win32
SetMemoryMax(256)
### export clip: msk
### pass clip: c, src, clip1
### platform: win32
SetMemoryMax(384)
clip2=src.msharpen(10, 120, mask=false, highq=true).spline64resize(1280, 720, 2, 2, -2, -1)
### export clip: clip2
### pass clip: c, src, clip1, msk
### platform: win32
SetMemoryMax(256)
次级版本号得按一个整数来看,11 > 9所以是没错的~rshadow 写了: 怎么看起来版本号好像倒退了……
感谢304测试~不过这结果看着好像有点问题,用MPP的码率比没有用多出了一截,不知道是什么原因呢orz-o-o-304-o-o- 写了:
x264设定(r2164tmod649)
c:\x264>x264 --preset ultrafast --frames 1000 -o null "E:\hunter02-ts.avs"
不用MPP
encoded 1000 frames, 6.3515 fps, 0.1574 spf, 3176.50 kb/s
x264 [info]: ended at Sat Mar 03 22:54:21 2012
x264 [info]: encoding duration 0:02:37
MPP v0.9
encoded 1000 frames, 5.6015 fps, 0.1785 spf, 3328.16 kb/s
x264 [info]: ended at Sat Mar 03 22:22:58 2012
x264 [info]: encoding duration 0:02:59
MPP v0.11
encoded 1000 frames, 7.0729 fps, 0.1414 spf, 3326.06 kb/s
x264 [info]: ended at Sat Mar 03 22:18:52 2012
x264 [info]: encoding duration 0:02:22
MPP v0.11 + lock threads to cores
encoded 1000 frames, 7.4965 fps, 0.1334 spf, 3330.49 kb/s
x264 [info]: ended at Sat Mar 03 22:31:46 2012
x264 [info]: encoding duration 0:02:14
0.9->0.11的累计提升达到了25%,对于一般情况都有超过10%的性能提升,效果令人满意,鸡动ing~~
快断电了,branch的效果明天再试……再次拜谢皮神~
哦哦感谢皮神,加了prefetch之后速度像打了鸡血一样的快啊(7.49->11.29)……再次拜谢皮神!SAPikachu 写了:次级版本号得按一个整数来看,11 > 9所以是没错的~rshadow 写了: 怎么看起来版本号好像倒退了……
不用MPP
MPP v0.9
MPP v0.11
PS:304可以试试在后面的几个进程加上prefetch,可能还能提高一点速度~
个位数的差别倒是没什么关系,主要是不用MPP和用MPP差了一百多K有点在意。。。-o-o-304-o-o- 写了: 哦哦感谢皮神,加了prefetch之后速度像打了鸡血一样的快啊(7.49->11.29)……再次拜谢皮神!
码率那个情况不知道,我这跑了3次码率都不一样,从3328->3330之间来回跳,同一个脚本跑出来的码率也是不完全一样的,回头我这用abr再测试一次好了……不过现在这个提升的比例早就超过误差的范围了,是巨大的速度提升啊~~~~
prefetch提速效果的测试结果已经更新到了原帖里面了……再三拜谢皮神!
这样啊,晚上回去关掉GF再试试去……06_taro 写了:GrainFactory3mod開動態噪點的話什麼都有可能的……
麻烦贴一下完整脚本和错误信息?mickoo 写了:请问这个怎么使用的?我根据LZ的例子,总是提示错误的?
