Billy Herrington
Re: [BUG]windows update后tMod在运行即将结束时崩溃
Then something in qtaac breaks unexpectedly
nfs
添加 --demuxer lavf 后出现
lavf失败
lavf失败
It seems that recently I should not use x264 for audio encoding-.-
Thanks Billy! ~\ASS WE CAN/~
也谢谢 free077go,虽然最新版没有解决问题:(
Billy Herrington
It is weird to see lavf demuxer getting read errors in such cases.
Could you please share your input mov source?
nfs
Billy Herrington 写了:It is weird to see lavf demuxer getting read errors in such cases.
I don't think it is demuxer's problem(qtaac enabled) because I have changed various kinds of video sources for testing.
The .mov file is a 1920×1080 DV clip {:cat_8}
Billy Herrington
No I didn't mean that one particular demuxer should be blamed ( though it is still possible if libavcodec fails, which would result in failures in nearly all popular free source filters ), I was thinking if the source filter itself is broken, or not compliant to satisfy most decoders. For an unrealistic example, it uses 13-bit depth which keeps within spec but can still challenge most decoders, if not all. I have to doubt about it because not only your system changes before/after installing the hotfix, but your souces varies unless you did exactly two encoding on the very same souce with same audio settings, which seems unreasonable to me so that I cannot help to avoid making such a silly assumption.
nfs
Well, thank you for helping, \♂Aniki♂/~
May be this is the final solution: remove that KB2670838 hotfix
with this
wusa.exe /uninstall /kb:2670838
and everything works well :)
I'm sure that during these days there are no more system changes except windows update(I have checked the system log in the Solution Center)
Maybe it is an incidental only happens to me. {:cat_13}
Re: [已解决][BUG?]补丁KB2670838安装后tMod在运行即将结束时崩溃
貌似这个补丁会造成部分DELL和HP的笔记本电脑出现崩溃,原因貌似是与板载AMD显卡存在冲突。
目前唯一的解决方法就是将其卸载、隐藏,然后等MS发布新版补丁。
参考
► 显示剧情透露 平庸的rip
► 显示剧情透露 “不知道”的五大理由
nfs
dgwxx 写了:原因貌似是与板载AMD显卡存在冲突。
参考
谢谢虾大
N家显卡,虽然没崩溃但是却出这样问题- .-……
已卸载,隐藏= =
Billy Herrington
Does x264 --demuxer lavf -o output.mp4 input.mov works again after removing that update?
No matter how system changs, lavf showing read error for a normal mov file is never intended and should be considered as a regression. Unlike qtaac depending on msvcrt, lavf demuxer does not require special system resources and generally won't be affected by such kind of updates.
nfs
To Billy,
After reading your reply I tried again deal with that DV clip with qtaac & lavf
You are right, lavf failed with that .mov file, but seems works well with other video source.
That's odd.
