Autobuild batchscript:
GitHub: media-autobuild_suite
For using it:
Download the file, and copy it in your target folder. In that folder all compiler and tools get installed. Please look that you use a folder without space characters. A good place is: c:\mingw
double click the media-autobuild_suite.bat file
select if you want to compile for Windows 32 bit, 64 bit or both
select if you want to compile non free tools like "fdk aac"
select the numbers of CPU (cores) you want to use
Wait a little bit, and hopefully after a while you found all your "*.exe" Tools under local32\bin, or local64\bin
Binary: https://mega.co.nz/#F!FkdFnYLa!azPzcnMZfDoMO3GvUiMcZg
FFmpeg version N-59185-ge10fccf
libavutil 52. 58.101 / 52. 58.101
libavcodec 55. 45.102 / 55. 45.102
libavformat 55. 22.100 / 55. 22.100
libavdevice 55. 5.102 / 55. 5.102
libavfilter 4. 0.100 / 4. 0.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
libpostproc 52. 3.100 / 52. 3.100
This FFmpeg build was configured with:
--enable-gpl --enable-version3 --enable-postproc --enable-w32threads --enable-runtime-cpudetect
--enable-memalign-hack --disable-shared --enable-static --enable-avfilter --enable-bzlib
--enable-zlib --enable-librtmp --enable-gnutls --enable-avisynth --enable-frei0r
--enable-filter=frei0r --enable-libbluray --enable-libcaca --enable-libopenjpeg --enable-fontconfig
--enable-libfreetype --enable-libass --enable-libgsm --enable-libmodplug --enable-libmp3lame
--enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc
--enable-libschroedinger --enable-libsoxr --enable-libtwolame --enable-libutvideo --enable-libspeex
--enable-libtheora --enable-libvorbis --enable-libvo-aacenc --enable-libopus --enable-libvidstab
--enable-libvpx --enable-libxavs --enable-libx264 --enable-libxvid --enable-libzvbi
--enable-nonfree --enable-libfaac --enable-libfdk-aac
