刚下载了THORA这个压制组的东西,用potplayer查看它的视频信息的时候是这样的
Format : Matroska
Format version : Version 4 / Version 2
File size : 15.4 GiB
Duration : 1h 8mn
Overall bit rate : 32.0 Mbps
Movie name : Mardock Scramble 3 - The Third Exhaust
Encoded date : UTC 2013-10-19 13:38:18
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video #1
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 8mn
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Bit depth : 8 bits
Scan type : Progressive
Title : H.264
Language : Japanese
Default : Yes
Forced : No
视频根本查不到Encoding settings信息,但确实是x264文件啊,这是怎么办到的,是在x264.exe里面下手脚还是封装的时候去掉的,求大神解答
