如题,很蛋疼的事情,x264设置没有什么问题,AVS也很正常,如果只是压制前面的小片段,放到psp里正常播放,但是压制40多分钟的整片放进去就说是不兼容的数据……,psp里按三角看信息自解析度开始往下全是 -- 。希望高手解答。
附不兼容文件信息:
D:\lamu_hd-muxed.mp4
General
Complete name : D:\lamu_hd-muxed.mp4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 463 MiB
Duration : 47mn 38s
Overall bit rate : 1 360 Kbps
Encoded date : UTC 2011-04-09 15:41:26
Tagged date : UTC 2011-04-09 15:41:26
Video #1
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=1, N=3
Codec ID : avc1
Duration : 47mn 38s
Bit rate mode : Variable
Bit rate : 1 172 Kbps
Maximum bit rate : 4 649 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.141
Stream size : 399 MiB (86%)
Title : àF
Writing library : x264 core 114 r1913 5fd3dce
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x131 / me=umh / subme=7 / psy=1 / psy_rd=0.50:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2011-04-09 15:42:00
Audio #2
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 47mn 38s
Bit rate : 184 Kbps
Maximum bit rate : 215 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 62.7 MiB (14%)
Encoded date : UTC 2011-04-09 15:41:55
另附相同设置能正常播放的文件信息:
J:\VIDEO\[FLsnow][Fate_stay_night][NCOP1][BDrip][720p][AVC_AAC]-muxed.mp4
General
Complete name : J:\VIDEO\[FLsnow][Fate_stay_night][NCOP1][BDrip][720p][AVC_AAC]-muxed.mp4
Format : MPEG-4
Codec ID : MSNV
File size : 13.5 MiB
Duration : 1mn 31s
Overall bit rate : 1 247 Kbps
Encoded date : UTC 2011-04-09 09:45:48
Tagged date : UTC 2011-04-09 09:45:48
Video #1
Codec ID : avc1
Duration : 1mn 31s
Bit rate : 1 053 Kbps
Maximum bit rate : 3 426 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.127
Stream size : 11.4 MiB (84%)
Title : @
Tagged date : UTC 2011-04-09 09:45:49
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 31s
Bit rate : 192 Kbps
Maximum bit rate : 204 Kbps
Stream size : 2.06 MiB (15%)
Encoded date : UTC 2011-04-09 09:45:49
