ffms [info]:
Codec : h264
PixFmt : yuv420p
Timebase : 0/1000000
Duration : 0:23:22
ffms [info]: 640x480p 1:1 @ 30000/1001 fps (vfr)
ffms [info]: color matrix: bt709
crop [info]: cropping to 636x480
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x264 [info]: profile High 10, level 3.0, 4:2:0 10-bit
x264 [info]: cabac=1 ref=4 deblock=1:0:0 analyse=0x3:0x133 me=umh subme=10 psy=1
fade_compensate=0.00 psy_rd=0.00:0.00 mixed_ref=1 me_range=24 chroma_me=1 trell
is=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 loo
kahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 c
onstrained_intra=0 fgo=0 bframes=5 b_pyramid=2 b_adapt=2 b_bias=0 direct=1 weigh
tb=1 open_gop=0 weightp=2 keyint=360 keyint_min=29 scenecut=40 intra_refresh=0 r
c_lookahead=40 rc=crf mbtree=1 crf=22.0000 qcomp=0.70 qpmin=0 qpmax=81 qpstep=4
ip_ratio=1.40 aq=1:1.00
x264 [info]: started at Thu Apr 04 11:00:20 2013
frames fps kb/s elapsed remain size est.siz
e
[ 0.0%] 1/42030 1.103 8786.7 0:00:00 10:35:20 35.79 KB 1469.0
[ 0.0%] 7/42030 5.705 0.60 0:00:01 2:02:46 62.41 KB 365.96
[ 0.0%] 14/42030 7.011 0.42 0:00:01 1:39:53 87.22 KB 255.70
[ 0.1%] 22/42030 8.943 0.40 0:00:02 1:18:17 133.17 KB 248.44
[ 0.1%] 30/42030 10.41 0.36 0:00:02 1:07:16 160.27 KB 219.28
[ 0.1%] 38/42030 11.49 0.33 0:00:03 1:00:54 185.17 KB 200.01
[ 0.1%] 46/42030 11.30 0.34 0:00:04 1:01:54 231.30 KB 206.39
[ 0.1%] 51/42030 11.46 0.32 0:00:04 1:01:02 244.46 KB 196.74
[ 0.1%] 56/42030 11.49 0.31 0:00:04 1:00:53 258.50 KB 189.46
[ 0.1%] 62/42030 11.92 0.30 0:00:05 0:58:41 282.00 KB 186.68
[ 0.2%] 70/42030 11.91 0.31 0:00:05 0:58:41 326.97 KB 191.72
[ 0.2%] 78/42030 12.36 0.30 0:00:06 0:56:35 352.26 KB 185.37
[ 0.2%] 82/42030 11.89 0.30 0:00:06 0:58:46 365.03 KB 182.71
[ 0.2%] 90/42030 12.43 0.29 0:00:07 0:56:12 392.63 KB 179.06
[ 0.2%] 98/42030 13.07 0.30 0:00:07 0:53:29 433.38 KB 181.51
[ 0.2%] 102/42030 13.02 0.29 0:00:07 0:53:39 446.17 KB 179.54
[ 0.3%] 110/42030 13.34 0.29 0:00:08 0:52:22 478.30 KB 178.47
[ 0.3%] 116/42030 13.62 0.28 0:00:08 0:51:16 494.25 KB 174.88
[ 0.3%] 121/42030 13.38 0.29 0:00:09 0:52:13 530.07 KB 179.81
[ 0.3%] 131/42030 14.03 0.29 0:00:09 0:49:46 560.78 KB 175.70
[ 0.3%] 138/42030 14.24 0.28 0:00:09 0:49:01 578.49 KB 172.06
[ 0.3%] 140/42030 13.79 0.28 0:00:10 0:50:38 581.03 KB 170.34
[ 0.4%] 148/42030 14.23 0.27 0:00:10 0:49:04 606.88 KB 168.31
[ 0.4%] 149/42030 13.47 0.28 0:00:11 0:51:48 635.18 KB 174.97
[ 0.4%] 157/42030 13.83 0.28 0:00:11 0:50:27 655.44 KB 171.35
[ 0.4%] 162/42030 13.87 0.28 0:00:11 0:50:18 673.37 KB 170.61
[ 0.4%] 169/42030 14.06 0.28 0:00:12 0:49:37 705.67 KB 171.39
[ 0.4%] 174/42030 14.13 0.28 0:00:12 0:49:22 720.25 KB 169.90
[ 0.4%] 183/42030 14.31 0.27 0:00:12 0:48:44 741.68 KB 166.35
[ 0.4%] 189/42030 14.45 0.27 0:00:13 0:48:15 752.87 KB 163.50
[ 0.5%] 191/42030 14.25 0.27 0:00:13 0:48:55 757.08 KB 162.69
[ 0.5%] 198/42030 14.19 0.27 0:00:13 0:49:08 794.06 KB 164.61
[ 0.5%] 206/42030 14.44 0.26 0:00:14 0:48:17 814.46 KB 162.28
[ 0.5%] 214/42030 14.45 0.27 0:00:14 0:48:13 849.64 KB 162.96
[ 0.5%] 222/42030 14.49 0.26 0:00:15 0:48:06 870.33 KB 160.91
[ 0.5%] 227/42030 14.13 0.26 0:00:16 0:49:18 884.29 KB 159.89
[ 0.6%] 233/42030 14.26 0.26 0:00:16 0:48:51 903.52 KB 159.16
[ 0.6%] 238/42030 14.07 0.26 0:00:16 0:49:31 935.36 KB 161.31
[ 0.6%] 246/42030 14.20 0.26 0:00:17 0:49:02 952.68 KB 158.95
[ 0.6%] 252/42030 14.33 0.26 0:00:17 0:48:35 963.69 KB 156.96
[ 0.6%] 258/42030 14.34 0.25 0:00:17 0:48:32 979.27 KB 155.79
[ 0.6%] 261/42030 14.12 0.25 0:00:18 0:49:18 981.85 KB 154.41
[ 0.6%] 272/42030 14.49 0.25 0:00:18 0:48:01 1022.00 KB 154.22
[ 0.7%] 278/42030 14.55 0.25 0:00:19 0:47:48 1.01 MB 153.11
[ 0.7%] 285/42030 14.71 0.25 0:00:19 0:47:17 1.02 MB 151.11
[ 0.7%] 286/42030 14.54 0.25 0:00:19 0:47:51 1.05 MB 153.69
[ 0.7%] 294/42030 14.75 0.25 0:00:19 0:47:10 1.06 MB 151.98
[ 0.7%] 302/42030 14.95 0.24 0:00:20 0:46:31 1.08 MB 150.31
[ 0.7%] 309/42030 15.11 0.24 0:00:20 0:46:01 1.09 MB 148.83
[ 0.7%] 311/42030 14.78 0.24 0:00:21 0:47:01 1.10 MB 148.05
[ 0.8%] 325/42030 15.20 0.24 0:00:21 0:45:43 1.13 MB 146.28
"??????\x264 mod\x264_rev2274+704_tMod-FFmpeg\tMod-10bit\x264_64_tMod-10bit-420.exe" --profile high10 --vf crop:0,0,4,0 --crf 22 --subme 10 --me umh --bframes 5 --ref 4 --psy-rd 0:0 --aq-strength 1.0 --qcomp 0.7 --keyint 360 --b-adapt 2 --trellis 2 --merange 24 --partition all --acodec none --stylish --log-file "xxx.TXT" -o "xxx.mkv" "yyy.mkv"
这个版本用mkv做输入文件就会出这个问题chrisrex 写了:taro你好,鄙人用下载了你的r2274+704v2版x264,用命令行进行裸压,发现数据量只有0.几k/s,而播放时间就有几百小时,不知是否我用得不正确呢,而用r2245+704版就没有这个问题,特此报告一下
因找不到上传图片方法,特复制命令行的信息代码: 全选
ffms [info]: Codec : h264 PixFmt : yuv420p Timebase : 0/1000000 Duration : 0:23:22 ffms [info]: 640x480p 1:1 @ 30000/1001 fps (vfr) ffms [info]: color matrix: bt709 crop [info]: cropping to 636x480 x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x264 [info]: profile High 10, level 3.0, 4:2:0 10-bit x264 [info]: cabac=1 ref=4 deblock=1:0:0 analyse=0x3:0x133 me=umh subme=10 psy=1 fade_compensate=0.00 psy_rd=0.00:0.00 mixed_ref=1 me_range=24 chroma_me=1 trell is=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 loo kahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 c onstrained_intra=0 fgo=0 bframes=5 b_pyramid=2 b_adapt=2 b_bias=0 direct=1 weigh tb=1 open_gop=0 weightp=2 keyint=360 keyint_min=29 scenecut=40 intra_refresh=0 r c_lookahead=40 rc=crf mbtree=1 crf=22.0000 qcomp=0.70 qpmin=0 qpmax=81 qpstep=4 ip_ratio=1.40 aq=1:1.00 x264 [info]: started at Thu Apr 04 11:00:20 2013 frames fps kb/s elapsed remain size est.siz e [ 0.0%] 1/42030 1.103 8786.7 0:00:00 10:35:20 35.79 KB 1469.0 [ 0.0%] 7/42030 5.705 0.60 0:00:01 2:02:46 62.41 KB 365.96 [ 0.0%] 14/42030 7.011 0.42 0:00:01 1:39:53 87.22 KB 255.70 [ 0.1%] 22/42030 8.943 0.40 0:00:02 1:18:17 133.17 KB 248.44 [ 0.1%] 30/42030 10.41 0.36 0:00:02 1:07:16 160.27 KB 219.28 [ 0.1%] 38/42030 11.49 0.33 0:00:03 1:00:54 185.17 KB 200.01 [ 0.1%] 46/42030 11.30 0.34 0:00:04 1:01:54 231.30 KB 206.39 [ 0.1%] 51/42030 11.46 0.32 0:00:04 1:01:02 244.46 KB 196.74 [ 0.1%] 56/42030 11.49 0.31 0:00:04 1:00:53 258.50 KB 189.46 [ 0.1%] 62/42030 11.92 0.30 0:00:05 0:58:41 282.00 KB 186.68 [ 0.2%] 70/42030 11.91 0.31 0:00:05 0:58:41 326.97 KB 191.72 [ 0.2%] 78/42030 12.36 0.30 0:00:06 0:56:35 352.26 KB 185.37 [ 0.2%] 82/42030 11.89 0.30 0:00:06 0:58:46 365.03 KB 182.71 [ 0.2%] 90/42030 12.43 0.29 0:00:07 0:56:12 392.63 KB 179.06 [ 0.2%] 98/42030 13.07 0.30 0:00:07 0:53:29 433.38 KB 181.51 [ 0.2%] 102/42030 13.02 0.29 0:00:07 0:53:39 446.17 KB 179.54 [ 0.3%] 110/42030 13.34 0.29 0:00:08 0:52:22 478.30 KB 178.47 [ 0.3%] 116/42030 13.62 0.28 0:00:08 0:51:16 494.25 KB 174.88 [ 0.3%] 121/42030 13.38 0.29 0:00:09 0:52:13 530.07 KB 179.81 [ 0.3%] 131/42030 14.03 0.29 0:00:09 0:49:46 560.78 KB 175.70 [ 0.3%] 138/42030 14.24 0.28 0:00:09 0:49:01 578.49 KB 172.06 [ 0.3%] 140/42030 13.79 0.28 0:00:10 0:50:38 581.03 KB 170.34 [ 0.4%] 148/42030 14.23 0.27 0:00:10 0:49:04 606.88 KB 168.31 [ 0.4%] 149/42030 13.47 0.28 0:00:11 0:51:48 635.18 KB 174.97 [ 0.4%] 157/42030 13.83 0.28 0:00:11 0:50:27 655.44 KB 171.35 [ 0.4%] 162/42030 13.87 0.28 0:00:11 0:50:18 673.37 KB 170.61 [ 0.4%] 169/42030 14.06 0.28 0:00:12 0:49:37 705.67 KB 171.39 [ 0.4%] 174/42030 14.13 0.28 0:00:12 0:49:22 720.25 KB 169.90 [ 0.4%] 183/42030 14.31 0.27 0:00:12 0:48:44 741.68 KB 166.35 [ 0.4%] 189/42030 14.45 0.27 0:00:13 0:48:15 752.87 KB 163.50 [ 0.5%] 191/42030 14.25 0.27 0:00:13 0:48:55 757.08 KB 162.69 [ 0.5%] 198/42030 14.19 0.27 0:00:13 0:49:08 794.06 KB 164.61 [ 0.5%] 206/42030 14.44 0.26 0:00:14 0:48:17 814.46 KB 162.28 [ 0.5%] 214/42030 14.45 0.27 0:00:14 0:48:13 849.64 KB 162.96 [ 0.5%] 222/42030 14.49 0.26 0:00:15 0:48:06 870.33 KB 160.91 [ 0.5%] 227/42030 14.13 0.26 0:00:16 0:49:18 884.29 KB 159.89 [ 0.6%] 233/42030 14.26 0.26 0:00:16 0:48:51 903.52 KB 159.16 [ 0.6%] 238/42030 14.07 0.26 0:00:16 0:49:31 935.36 KB 161.31 [ 0.6%] 246/42030 14.20 0.26 0:00:17 0:49:02 952.68 KB 158.95 [ 0.6%] 252/42030 14.33 0.26 0:00:17 0:48:35 963.69 KB 156.96 [ 0.6%] 258/42030 14.34 0.25 0:00:17 0:48:32 979.27 KB 155.79 [ 0.6%] 261/42030 14.12 0.25 0:00:18 0:49:18 981.85 KB 154.41 [ 0.6%] 272/42030 14.49 0.25 0:00:18 0:48:01 1022.00 KB 154.22 [ 0.7%] 278/42030 14.55 0.25 0:00:19 0:47:48 1.01 MB 153.11 [ 0.7%] 285/42030 14.71 0.25 0:00:19 0:47:17 1.02 MB 151.11 [ 0.7%] 286/42030 14.54 0.25 0:00:19 0:47:51 1.05 MB 153.69 [ 0.7%] 294/42030 14.75 0.25 0:00:19 0:47:10 1.06 MB 151.98 [ 0.7%] 302/42030 14.95 0.24 0:00:20 0:46:31 1.08 MB 150.31 [ 0.7%] 309/42030 15.11 0.24 0:00:20 0:46:01 1.09 MB 148.83 [ 0.7%] 311/42030 14.78 0.24 0:00:21 0:47:01 1.10 MB 148.05 [ 0.8%] 325/42030 15.20 0.24 0:00:21 0:45:43 1.13 MB 146.28
而鄙人用的x264命令行是:代码: 全选
http://www.nmm-hd.org/newbbs/viewtopic. ... =219#p1674chrisrex 写了:原来是这样,不知道哪里能看到更新内容呢?想看看实际更新了些什么,如果不是重大更新的话就不用升级得那么频繁了
