xijiao2000 写了:输入10bit视频时挂字幕编码时必出错。。怎么办
06_taro 写了:ReadMe-how_to_load_subtitles.txt 写了:
Both 8-bit and 10-bit builds can use subtitles rendering, but rendering should only take place in 8-bit colorspaces. For example, if the input video is 10-bit, which would be converted to yuv420p16le internally before encoding, you need to use "resize" filter to downscale it to 8-bit before "subtitles" filter:代码: 全选
--video-filter resize:csp=i420:8/subtitles --sub "subtitles.ass"
