前几天重装系统 win7 x86
然后今天用皮神2pass脚本压制出现错误
tmod用的taro大最新版的
确定不是参数设置问题(试了皮神的sample脚本也一样)
错误信息如下
多谢解答
File "D:\Python31\lib\site-packages\cx_Freeze\initscripts\Console3.py", line 27, in <module>
File "encx264.py", line 23, in <module>
File "D:\Tools\Playin Packet\MP4\INDirect2642\INDirect264\impls\encx264_impl.py", line 423, i
n encode
return encode_impl(args, print, working_dir=working_dir, Popen=Popen)
File "D:\Tools\Playin Packet\MP4\INDirect2642\INDirect264\impls\encx264_impl.py", line 282, i
n encode_impl
args = get_params(raw_args, print, working_dir)
File "D:\Tools\Playin Packet\MP4\INDirect2642\INDirect264\impls\encx264_impl.py", line 181, i
n get_params
print("{0} doesn't exist!".format(inFile))
UnicodeEncodeError: 'gbk' codec can't encode character '\uff64' in position 23: illegal multiby
te sequence
ffmpeg version N-45739-g04bf2e7 Copyright (c) 2000-2012 the FFmpeg developers
built on Oct 20 2012 10:30:46 with gcc 4.7.2 (GCC)
configuration: --prefix=/mingw/i686-w64-mingw32 --enable-nonfree --target-os=mingw32 --arch=x
86 --cpu=i686 --enable-gpl --enable-version3 --enable-postproc --enable-w32threads --enable-run
time-cpudetect --enable-memalign-hack --enable-avisynth --enable-bzlib --enable-libopencore-amr
nb --enable-libopencore-amrwb --enable-libgsm --enable-libopus --enable-libmp3lame --enable-lib
openjpeg --enable-librtmp --enable-libspeex --enable-libschroedinger --enable-libtheora --enabl
e-libvorbis --enable-libvo-amrwbenc --enable-libvo-aacenc --enable-libfdk-aac --enable-libfaac
--enable-libx264 --enable-libxvid --enable-libxavs --enable-libvpx --enable-libutvideo --disabl
e-dxva2 --disable-ffplay --disable-ffserver --disable-doc --disable-debug --disable-network --e
xtra-ldflags='-Wl,--large-address-aware -s' --extra-cflags='-march=i686 -mtune=generic -mfpmath
=sse -msse -fomit-frame-pointer -fexcess-precision=fast -fno-tree-vectorize -Ofast'
libavutil 51. 76.100 / 51. 76.100
libavcodec 54. 67.100 / 54. 67.100
libavformat 54. 33.100 / 54. 33.100
libavdevice 54. 3.100 / 54. 3.100
libavfilter 3. 19.103 / 3. 19.103
libswscale 2. 1.101 / 2. 1.101
libswresample 0. 16.100 / 0. 16.100
libpostproc 52. 1.100 / 52. 1.100
qaac 1.41, CoreAudioToolbox 7.9.7.8
<stdin>
Input #0, matroska,webm, from 'E:\PSV contents\Video\閶笺伄閷瑍1\_HKG__~2.MKV':
Metadata:
creation_time : 2009-04-07 08:36:26
Duration: 01:44:56.25, start: 0.000000, bitrate: 9984 kb/s
Stream #0:0(eng): Video: h264 (Main), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.9
8 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(jpn): Audio: flac, 48000 Hz, 5.1(side), s16 (default)
Metadata:
title : FLAC 5.1ch
Stream #0:2(jpn): Audio: flac, 48000 Hz, stereo, s16
Metadata:
title : FLAC 2ch
Stream #0:3(eng): Audio: dts (DTS), 48000 Hz, stereo, fltp, 448 kb/s
Metadata:
title : DTS 2ch
Output #0, wav, to 'pipe:':
Metadata:
ISFT : Lavf54.33.100
Stream #0:0(jpn): Audio: pcm_f32le ([3][0][0][0] / 0x0003), 48000 Hz, 5.1(side), flt, 9216
kb/s (default)
Metadata:
title : FLAC 5.1ch
Stream mapping:
Stream #0:1 -> #0:0 (flac -> pcm_f32le)
AAPress [q] to stop, [?] for help
C-LC Encoder, TVBR q54, Quality 96
1:31.328 (6.2x) size= 98304kB time=00:01:27.38 bitrate=9216.1kbits/s
